CCME : Fax from E1 PRI to Cisco ATA186 SIP
Apr 22nd, 2009
How to enable fax on a E1 PRI link?
Should it configured from the Telco Service Privider?
If the provider enable the FAX on the E1 link using a DID, how to enable this on my CCME.
In the CCME, I think that I just use a simple Dial-peer voice to connect to the ATA186, like this :
dial-peer voice 100 voip
description To Cisco ATA186
destination-pattern 49..
session protocol sipv2
session target ipv4:172.16.1.2
dtmf-relay rtp-net
codec g711ulaw
no vad
I'm using a C2811, IOS=12.4(11)T
Is it correct?
Is there a weblink about configuring fax with PRI lines.
Best regards,
Antra
Overall Rating: 5 (3 ratings)
paolo bevilacqua Thu, 04/23/2009 - 09:57
  • Hall of Fame,
    Founding Member
Yes, that is fine. Remember you need network-clock-participate and network-clock-select for the PRI. Then you have problems search, "ata fax troubleshoot".
iantra123 Thu, 04/23/2009 - 22:57
There is 3 number that have been configured by the Telco provider for us.
2 of them is configured for Fax.
There is no problem about DID, I just use translation rules.
My question is :
Does Fax is enabled by default on the PRI Line (Controller E1, serial 0/0/0:15,voice-port 0/0/0:15, IOS)?
Do I need tape some commands to enable the FAX into the PRI Line.
Best regards
paolo bevilacqua Fri, 04/24/2009 - 05:59
  • Hall of Fame,
    Founding Member
1 - Yes. Router doesn't know it is a fax unless you do special configuration for that.
2 - No.
iantra123 Mon, 04/27/2009 - 03:33
"1. Yes. Router doesn't know it is a fax unless you do special configuration for that. "
I don't understand about this special configuration.
Can you give me some examples.
Best regards.
paolo bevilacqua Mon, 04/27/2009 - 04:03
  • Hall of Fame,
    Founding Member
That would be fax relay or fax email.
It is not your case and you do not need to worry about it.
