IP to X.25
Apr 22nd, 2009
I have an application where I would like to map IP addresses on Ethernet to a router connecting via x.25 to many remote sites. Is there an IOS feature where I can create a routing/lookup table that equates an IP address with an X.25 address for up to 2,000 X.25 nodes?
paolo bevilacqua Wed, 04/22/2009 - 10:32
  • Hall of Fame,
    Founding Member
Yes, that is a normal use for X.25 in IOS.
michaelbroche Wed, 04/22/2009 - 10:38
Thank you p.bevilacqua.
Is there a particular IOS command/feature you would recommend and does it require the Enterprise version of IOS?
Mike
michaelbroche Wed, 04/22/2009 - 10:54
Thank you again.
The only difference with my app is that I would use an ip address on a single host mapped x.25 devices over an x.25 cloud. More like TCP over X.25.
Can it still work?
DNS is good idea... : )
paolo bevilacqua Wed, 04/22/2009 - 10:56
  • Hall of Fame,
    Founding Member
Sorry, I do not quite understand what is you case.
michaelbroche Wed, 04/22/2009 - 11:02
Sngle IP host conencted to router via Ethernet. The host sends to a variety of IP addresses on the same subnet which are forwarded to a single router (default gateway). Each IP address in the subnet maps to an x.25 remote address accessed through an x.25 cloud.
paolo bevilacqua Wed, 04/22/2009 - 11:12
  • Hall of Fame,
    Founding Member
That is normal working and you can use the DNS feature, or configure the mapping in the router, as you prefer.
