Backup for IPCC Express
Apr 22nd, 2009
With IPCC Express on the Backup Storage Location Page, there is a text box to put in "Path Name". What format do you do this in since the format I will list below did not work.
\\Gummi\home\ipcc
Gummi is the name of the server, do I need to put the IP Address instead?
Chris Deren Wed, 04/22/2009 - 11:19
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Either one should work, if you are putting hostname make sure DNS can resolve it, try pinging it from the machine.
Also instead of doing home\ipcc I would share the ipcc folder and then simply use \\Gummi\ipcc format.
HTH,
Chris
