04-22-2009 08:11 AM - edited 03-06-2019 05:19 AM
Have a 48 port 3750 switch that I am connecting to a 24 port 2950. I just want to get the 48 port on net to download firmware. When I do, I get the Spantree error above.
I configure port 48 on the 3750 as this:
interface FastEthernet1/0/48
switchport access vlan 206
switchport trunk native vlan 206
switchport mode access
and port 13 on the 2950 as this:
interface FastEthernet0/13
switchport voice vlan 207
switchport priority extend trust
srr-queue bandwidth share 10 10 60 20
srr-queue bandwidth shape 10 0 0 0
mls qos trust device cisco-phone
mls qos trust cos
auto qos voip cisco-phone
spanning-tree portfast
(I turned off the port-fast to in order to see if that was it)
If I did not want to set both ports to switchport mode dynamic desirable (which actually works, but then the ports become trunk ports) How would I do this. I just want to get the 3750 onto Vlan 206, configure an IP address on it, and download firmware.
Thanks for your help,
Gene
Solved! Go to Solution.
04-22-2009 09:12 AM
Hello Gene,
remove
on both ports this build an implicit two vlans trunk (the mini trunk)
Hope to help
Giuseppe
04-22-2009 09:15 AM
Why not directly connecting your pc to the 3750 switch?
If you just want to allow vlan 206 between the switches and don't want the link to be a trunk:
Following minimal config is required
int fas0/13
on 3750
you don't need these commands for an access port:
If you are on the 3750 and wants to access the IOS from another vlan, make sure to have ip default-gateway configured
04-22-2009 09:12 AM
Hello Gene,
remove
Hope to help
Giuseppe
04-22-2009 09:15 AM
int fas0/13
on 3750
