ACS Engine Failover Deployment
Apr 22nd, 2009
I want reference guide for implementing ACS Engine Failover Deployment, I could not find any scenario for deploying Failover.
abuatiya Fri, 05/01/2009 - 13:51
Thanks for your reply. I have deployed same as mentioned in the document and working perfectly for the replication.
But i have serious problem. if i disconnect the network cable or restart the unit for example the primary one, the IP address on AAA server changed from the private IP 192.168.x.x to loopback IP
Please advice.
