7921 CCM 4.1 Web Access AXL
Apr 22nd, 2009
BAT only has 2 options for web access, enabled and disabled.
I need to enable web access on our 7921's for a change. Then I want to set it back to read only after I'm done. Anyone know if I can do this with AXL? I couldn't find it when I was looking. Or another solution would work too, as long as I don't have to manually change the setting on 2000 7921 phones.
msabir Wed, 04/22/2009 - 12:52
Did you look at Bulk Admin Tool (BAT). I don't have the CUCM interface in front of me at the moment. but you can usually make changes on bulk of phones using BAT. We use it to change the authentication URL for all the phones that we should be able to page.
setonhnet Wed, 04/22/2009 - 13:24
"BAT only has 2 options for web access, enabled and disabled."
