4506 slot 6 issue
Apr 22nd, 2009
I have an older style 4506 running CAT-OS. When I add a POE blade to slot 6 it is unrecognized by the chassis.
Here is a show version from the switch.
QuadB_3 (enable) sh ver
WS-C4506 Software, Version NmpSW: 7.4(2)
Copyright (c) 1995-2002 by Cisco Systems, Inc.
NMP S/W compiled on Oct 8 2002, 18:12:59
GSP S/W compiled on Oct 08 2002, 15:54:51
System Bootstrap Version: 5.4(1)
Hardware Version: 5.1 Model: WS-C4506 Serial #: FOX34371IJ2
Mod Port Model Serial # Versions
1 2 WS-X4013 JAE07091S4Y Hw : 5.1
Gsp: 7.4(2.0)
Nmp: 7.4(2)
2 48 WS-X4148-RJ45V JAB04081D6N Hw : 2.6
3 48 WS-X4148-RJ JAB04081ESM Hw : 3.1
4 48 WS-X4148-RJ JAB04081SW2 Hw : 3.1
5 48 WS-X4148-RJ JAB04220JUT Hw : 3.1
DRAM FLASH NVRAM
Module Total Used Free Total Used Free Total Used Free
1 65536K 39986K 25550K 16384K 5520K 10864K 480K 434K 46K
Uptime is 7 days, 21 hours, 2 minutes
glen.grant Thu, 04/23/2009 - 05:45
  • Purple, 4500 points or more
Whats the card model # ?
anowell Thu, 04/23/2009 - 07:06
Thanks for the response!
WS-X4148-RJ45
Please keep in mind that this blade works in slot 2.
Thanks again!
glen.grant Thu, 04/23/2009 - 07:19
Do other cards work in slot 6 ?? also you might want to check the power , the old catos boxes had limited PS's and it may not be enough to power 2 POE blades , don't know for sure though . Does it show anything in the log for when you plug the card in ?
