Unity Connection 7 and alternate extensions
Answered Question
Apr 22nd, 2009
Hello folks
I have unity connection 7 and a shared voice mail. If I configure multiple extensions on MWI it doesn't lid the light on the phone if I set it to notify the user on the secondary or tertiary extension, only on the primary. it only shows the envelope
Do you know a way to solve this?
Correct Answer by Chris Deren about 7 years 9 months ago
This is a CallManager configuration, check out "Visual Message Waiting Indicator Policy" setting on the Line or to change the default behavior adjust global service parameter of the same name.
HTH,
Chris
Overall Rating: 5 (1 ratings)
Correct Answer
Chris Deren Wed, 04/22/2009 - 11:27
HTH,
Chris
