PIX 515E upgrade problem
techtips03
Problem1: I am trying to upgrade pix 515e from 6.3(1) to 8.0(4) version in monitor mode and I am not able to do that.
monitor>interface 1
address 192.168.16.250
server 192.168.16.20 (my laptop with tftp program on)
file pix804.bin
tftp
I get the below
monitor> tftp
tftp pix804.bin@192.168.16.20
TFTP failed (return:-1 arg:0x0)
Laptop to pix (no ping response)
Pix console to laptop (pin ok)
Pix console to pix interface 1 192.168.16.250 (no ping response)
I went through these forums and tried with different tftp programs (cisco tftp, 3cdaemon, pumpkin, tftpd32) and no luck.
problem2:
On show version, I see
This PIX has a Failover Only (FO) license.
Can this only be used with only active/failover config? What should I do if I want to use as a normal standalone firewall.
Please advise.
tnetusa123
try below
failover active
conf t
interface e0
description firewall Interface
security-level 100
ip address 10.1.1.82 255.255.255.0
no shut
end
networker99
If you have no ping then you have a connectivity issue.. Try going through a switch to connect the PIX and PC, or verify the cross over cable
I checked both ways connecting through the switch and also with crossover. No luck. I wonder why its own interface is not pingable!
Any other opinions?
If not this how can I upgrade through the interface command. I have a hard time mentioning the right path. The file is on my desktop
