Why MTU sizes are different on the same interface?
Apr 22nd, 2009
MYRO#show ip int tu0
Tunnel0 is up, line protocol is up
Internet address is 10.10.110.22/30
Broadcast address is 255.255.255.255
Address determined by non-volatile memory
MTU is 1395 bytes
MYRO#show int tu0
Hardware is Tunnel
Description: IPSec VTI to HIM via SibirTCOMM
MTU 1514 bytes, BW 512 Kbit/sec, DLY 500000 usec,
Richard Burts Wed, 04/22/2009 - 11:21
Tim
Your outputs are a generic show interface and a show ip interface. Would I be correct is assuming that the tunnel interface included a config command of ip mtu 1395?
I believe that the difference that you are seeing is the difference between the physical interface MTU and the MTU used by IP processing on that interface.
Rick
SludnevTN_2 Wed, 04/22/2009 - 11:36
Thank you Rick.
Here is tunnel configuration
MYRO#show run int tu0
Building configuration...
Current configuration : 267 bytes
interface Tunnel0
description IPSec VTI to HIM via SibirTCOMM
bandwidth 512
ip address 10.10.110.22 255.255.255.252
qos pre-classify
tunnel source 87.103.133.13
tunnel destination 89.175.97.74
tunnel mode ipsec ipv4
tunnel protection ipsec profile KM4
What I am trying to find out:
As you see this is the tunnel from point A to point B via Internet.
I am experiencing a low rate smb file transfers (20 - 40 kbytes/sec - or 160 Kbits/s - 255 Kbits/s).
Point A Internet bandwidth 10 Mbit/s; C3845
Point B Internet bandwidth 512 Kbit/s; C2621XM
But why it is so slow? I am expecting file transfer about 60 Kbyte/s or 480 Kbit/s. Is it encryption overhead?
Richard Burts Wed, 04/22/2009 - 11:46
Tim
I would guess that it is primarily the encryption overhead. Would I be correct in assuming that the 2621XM (and perhaps the 3845) does not have the module (AIM or VPN module) for the hardware assist with encryption processing? If the encryption processing is being done in the router CPU there is likely to be a performance hit while doing this.
[edit] I see that there is not an ip mtu command as I had thought there might be. But I am pretty sure that this is being done automatically as a result of the tunnel protection ipsec processing.
Rick
SludnevTN_2 Wed, 04/22/2009 - 11:56
Rick, is it possible to speed up file transfers?
MYRO#show inventory
NAME: "2621XM chassis", DESCR: "2621XM chassis"
PID: C2621XM-2FE , VID: 1.0, SN: JAE073000HE
NAME: "Voice AIM with 4 DSPs 0", DESCR: "Voice AIM with 4 DSPs"
PID: 59-03 , VID: 1.0, SN: JAE07220ZZC
HIM#show inventory
NAME: "3845 chassis", DESCR: "3845 chassis"
PID: CISCO3845 , VID: V01 , SN: FCZ094872UH
NAME: "c3845 Motherboard with Gigabit Ethernet on Slot 0", DESCR: "c3845 Motherboard with Gigabit Ethernet"
PID: CISCO3845-MB , VID: V03 , SN: FOC0945267B
NAME: "4 Port FE Switch on Slot 0 SubSlot 0", DESCR: "4 Port FE Switch"
PID: HWIC-4ESW , VID: V01 , SN: FOC11122SRN
NAME: "One port E1 voice interface daughtercard on Slot 0 SubSlot 1", DESCR: "One port E1 voice interface daughtercard"
PID: VWIC-1MFT-E1= , VID: 1.0, SN: 35568679
NAME: "PVDMII DSP SIMM with four DSPs on Slot 0 SubSlot 4", DESCR: "PVDMII DSP SIMM with four DSPs"
PID: PVDM2-64 , VID: NA , SN: FOC09430DHX
Yes, there is no ip mtu command. I think this is not necessary. Am I correct?
SludnevTN_2 Wed, 04/22/2009 - 12:05
Also, I am monitoring file transfer in WIRE-SHARK.
I see a lot TCP retransmits.
Блять нахуй заебало все, спать пойду.
Richard Burts Wed, 04/22/2009 - 12:19
Tim
If you add the hardware accelerator to the routers I believe that it would speed up the file transfers. This link discusses the hardware accelerator for the 2621XM:
http://www.cisco.com/en/US/prod/collateral/routers/ps259/product_data_sheet0900aecd800fa5be.html
and look for references to AIM-VPN
This link discusses the hardware accelerator for the 3845:
http://www.cisco.com/en/US/prod/collateral/routers/ps5853/data_sheet_vpn_aim_for_18128003800routers_ps5855_Products_Data_Sheet.html
and again look for references to AIM-VPN
Rick
Richard Burts Wed, 04/22/2009 - 12:25
Tim
I now see your post which says you are monitoring with wireshark. If you are seeing lots of TCP retransmits then these would also impact the performance of the file transfer.
I am a bit puzzled about this. If the router is using IPSec to protect traffic through the tunnel, then I would expect that wireshark would see IPSec traffic using the ESP protocol rather than using TCP traffic.
Rick
Richard Burts Wed, 04/22/2009 - 12:56
Tim
Monitoring the inside interface would certainly explain why you are seeing TCP rather than ESP.
If there are TCP retransmissions they would impact the performance of the file transfer. And I am not sure that the hardware assist for encryption would change anything about the retransmissions.
Rick
