PPOE help only ever used PPOA on 877 routers
Apr 22nd, 2009
I have only ever configured Cisco 877 routers for PPOA ADSL lines in the UK, I now have to configure another 877 for a new VPN on Ireland which use PVC 8/38 (normally 0/38 in UK) and PPOE instead of PPOA.
I have the configure attched, what do I need to change for PPOE? I can see I need to change the PVC to 8/38, but I'm not sure from then on.
Collin Clark Thu, 04/23/2009 - 05:28
  • Purple, 4500 points or more
Here's the working config of my PPoE connection at home.
<font size="2"></p><p>interface FastEthernet0/1</p><p> description DSL WAN Interface</p><p> no ip address</p><p> no ip redirects</p><p> no ip unreachables</p><p> no ip proxy-arp</p><p> no ip mroute-cache</p><p> duplex auto</p><p> speed auto</p><p> pppoe enable</p><p> pppoe-client dial-pool-number 1</p><p>!</p><p>interface Dialer1</p><p> description DSL WAN Dialer$FW_OUTSIDE$</p><p> ip address negotiated</p><p> no ip unreachables</p><p> ip nat outside</p><p> ip virtual-reassembly</p><p> encapsulation ppp</p><p> no ip mroute-cache</p><p> dialer pool 1</p><p> dialer-group 1</p><p> no cdp enable</p><p> ppp authentication pap callin</p><p> ppp pap sent-username <a href="mailto:[email protected]">[email protected]</a> password 0 SeCrEt</p><p></p><p>dialer-list 1 protocol ip permit</font>
Hope that helps.
jamesgonzo Thu, 04/23/2009 - 09:00
Thanks, what router do you have? I think I have the wrong one, I have an 877 which has an ATM port and not and Ethernet like yours.
Collin Clark Thu, 04/23/2009 - 10:30
That's from an 871. Here's one from an 877.
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 0/35
dsl operating-mode auto
interface Dialer0
description Virtual Public Interface
ip address 75.50.95.73 255.255.255.248
ip access-group outside_in in
ip mtu 1452
ip flow ingress
ip inspect STATEFUL_FW out
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp chap hostname [email protected]
ppp chap password 0 SeCrEtPaSsWd
ppp pap sent-username [email protected] password 0 SeCrEtPaSsWd
ip route 0.0.0.0 0.0.0.0 Dialer0 permanent
As you stated before, you'll have to change the ATM pvc.
whiteford Thu, 04/23/2009 - 13:09
Great, apart from changing the PVC I notice the only other part I have to add is the ppoe setting under the ATM?
What are the differences between the ppoe and ppoa as thought it was just the port on the back, I immediately assumed as it was ethernet I would need an 871!
jamesgonzo Fri, 05/01/2009 - 01:39
Hi Collin,
Just one last thing, does this look ok on my 877 before I ship it off:
interface ATM0
no ip address
no ip mroute-cache
atm vc-per-vp 64
pvc 8/35
It was originally a PPOA router, so should I remove "atm vc-per-vp 64"?
interface Dialer1
ip access-group inbound in
encapsulation ppp
ip route-cache flow
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname eircom
ppp chap password 0 broadband
ppp pap sent-username broadband password 0 broadband
crypto map Crypto_Map
Collin Clark Fri, 05/01/2009 - 05:26
It won't hurt anything being in there. Make sure you create the dialer pool as well (it's not posted). Is the connection really ppp?
jamesgonzo Fri, 05/01/2009 - 05:31
I can see the dialer pool under my dialer 1 interface, or should this be somewhere else?
Are the DSL lines normally CHAP, is my config just using either PPP or CHAP?
