ASA5510 two inside interfaces
j.bourque
we have a client that is installing failover core switches. One will be in standby mode while the other is active. This will require two physical connections to the ASA5510 firewall. The ASA has one unused interface. Is it possible to assign both interfaces to the inside network, possibly using Vlans? They would like to avoid using a "dirty" switch inbetween the core switches and the firewall.
Collin Clark
A VLAN should work fine. Here's a link on configuring it in case you don't have it.
http://www.cisco.com/en/US/docs/security/asa/asa80/configuration/guide/int5505.html#wp1051819
Hope that helps.
