Is "no auto-summary" command relevant if performed under "vrf"?
Apr 22nd, 2009
I noticed that when I do:
myrouter#show ip protocols vrf MYTEST
Routing Protocol is "bgp 1000"
IGRP synchronization is disabled
Automatic route summarization is disabled
Other protocols listed under such command (such as OSPF) did not show any visible difference to me regardless if I enter "no auto-summary" under the respective "vrf" or not.
That said, my conclusion is that bgp summarization is disabled because it inherited the setting from the "router bgp 1000", in which "no auto-summary" was entered.
Questions:
That means that it is irrelevant doing "no auto-summary" under the 'address-family ipv4 vrf' instance?
The way I see it, it appears that as long as do "no auto-summary" under the respective "router protocol <>" line, the "no auto-summary" under "vrf" is ignored, right?
Giuseppe Larosa Thu, 04/23/2009 - 01:14
Hello Marlon,
I've checked on a PE node.
Even if the command no auto-summary is not present in the router bgp process it is disabled
Routing Protocol is "bgp XXXX"
Outgoing update filter list for all interfaces is not set
Incoming update filter list for all interfaces is not set
IGP synchronization is disabled
Maximum path: 1
Routing Information Sources:
Gateway Distance Last Update
Distance: external 20 internal 200 local 200
Then we have explicit no auto-summary under each af vrf but you probably are right because now BGP defaults to this.
Hope to help
Giuseppe
