Giuseppe Larosa Thu, 04/23/2009 - 01:25
  • Hall of Fame,
    Founding Member
Hello Patricio,
heavier duties are for the DR / BDR on lan segment.
In normal routing it is not recommended to have more then 40-50 routers in the same lan segment.
Possible suggestions are to divide in multiple lan segments, to use two PE nodes and make them DR alternate on vlans/subnets
Hope to help
Giuseppe
