Baseline standard for 3560E poe switches
Apr 22nd, 2009
Hi All,
woul dliek to create a baseline (standard) for configuring 3560 E POE switches.
kindly advice
Thanks and Regards,
Leo Laohoo Wed, 04/22/2009 - 14:33
Hi Jerry,
Like what Victor said, what are you PoE are you plugging to the port?
power inline port maximum 19500 < --- If you want enhanced PoE.
no power inline never < --- Enable power to a port.
Hope this helps.
jerry_best Wed, 04/22/2009 - 14:35
Connecting Avaya IP phone and pc to switchport. bseline standard in terms of audit. e.g. configure telent access restriction, service-password encryption, no ip http server Etc.
is there any standard templet is available.
kindly advice
