ASDM is unable to read the configuration from the ASA
Apr 22nd, 2009
Greeting
I have an ASA5520 with version 7.4.
I had a problem from sometime before.
I can not login using ASDM for some reason!
since last time I login using ASDM for just monitoring, what I only did is upgrade to new version.
Could anyone advice me what problem I have? And what should I do/check/change to let me in with full right to configure again?
By the way, ssh is working ok.
Any comments will be appreciated
Thanks in advance
dancarrick Wed, 04/22/2009 - 22:38
Was it a Java update? that always gets me, and I have now disabled auto updates for Java
Dan
cowmixtoo Tue, 04/28/2009 - 08:18
What version of Java works? because I'm having the SAME issue.
phillipediab Tue, 04/28/2009 - 12:48
I have ASDM 5.2(4) with Java 1.6.0 (build 1.6.0_02-b06) and it is working just fine.
phillipediab Tue, 04/28/2009 - 12:58
one thing i forgot to ask is when you upgraded your asa did upgrade your asdm to match the asa version ?
