is possible to hide configuration button on asdm?
Apr 22nd, 2009
Greeting
Can I hide configuration button on ASDM menu for read-only users?
Any comments will be appreciated
Thanks in advance
carenas123 Tue, 04/28/2009 - 10:46
  • Silver, 250 points or more
I think you can only able to hide the display of the Navigation pane in the configuration and monitoring views using navigation option in the view menu.
julxu Tue, 04/28/2009 - 16:57
Thanks for the reply and could you please advice how can I do it?
Thousands thanks.
mherald Sat, 05/02/2009 - 12:08
I am not positive that you can hide the configuration tab. However, if you use ACS with authorization, even though a user may have the configuration tab, they can not do commands outisde of the allowed set (or disallowed commands, depending on implementation).
Mike
