Cable between R3620 with card NM-8A/S (DB60) and Console (RJ45)
saturnvas508
I have Cisco 3620 router with NM-8A/S card with eight DB60 male connectors. I want to do terminal server (router 3620) and connect it to other Cisco devices on console port (RJ45). Which kind, cable type can i use? Could You help me?
I think this:
R3620_NM8A/S(DB60female)>><<(DB60male)--cable--(DB25male)>> <<(DB25female)--cable--(DB9male)>><<(DB9female)--console_cable--(RJ45male)>>
<<(RJ45female)consoleportSwitch_Cisco
Is this correct?
Mateusz
P.S. Sorry for my English.
Giuseppe Larosa
Hello Mateusz,
the cable setup you are suggesting looks like fine.
Hope to help
Giuseppe
Thanks for solution but I have some troubles.
Router(DB60) is DCE and console port Switch (RJ45) is always DTE.
Cable <<(DB60male)--cable--(DB25male)>> is Serial Cable CAB-232MT which is DTE cable.
I can use this cable??
Or I should use this:
<<(DB60male)--cable--(DB25female)>>
which is Serial Cable CAB-232FC DCE cable.
Could You help me?
Mateusz
Hello Mateusz,
you should have of the following two:
CAB-232MT
EIA/TIA -232 DTE
10 feet (3 meters)
Male
CAB-232FC
EIA/TIA -232 DCE
10 feet (3 meters)
Female
see
Hope to help
Giuseppe
