Giuseppe Larosa Wed, 04/22/2009 - 22:59
  • Hall of Fame,
    Founding Member
Hello Just,
in a lab environment you can use the old clear ip bgp * without no risk to have impact in a production network.
In general you can do what is not explicitly forbidden but adding unrequested commands require some time.
Hope to help
Giuseppe
hasmurizal Thu, 04/23/2009 - 00:09
the other way you may want to clear BGP routing table updates is to use;
"clear ip bgp x.x.x.x in" where x.x.x.x is your neighbor ip address. this way your router will prompt the neighbour router to re-sent bgp table update. much more safer in the production network.
guruprasadr Thu, 04/23/2009 - 00:23
  • Gold, 750 points or more
Hi Just,
In Production Environment Perspective:
-Occupies additional memory for storing routing update information.
Recommendations: -
-Use the dynamic soft reset method for resetting the BGP table using: clear ip bgp - - - - soft in/out
Hope I am Informative.
Pls RATE if HELPS
Best Regards,
Guru Prasad R
