UCCX 7.01 - Backup/Restore
metalium2007
Level 3
Level 3
Is all reporting information stored on backups for restore?
So, if i do a backup and restore to a new server is all the historical info migrated?
Met.
ra_jeshkalra_2
All DBs are backed up, the main DB is db_cra.
See the following:
What is backed up?
• Clusters, configurations, and applications profile in the data repository
• Workflow scripts that are already uploaded in the data repository
• The db_cra repository, FCRasSvr database
• Unified IVR configuration data (such as open bootstrap and flat files)
• Unified IVR recording files
• Windows hosts and lmhosts
• Unified CM Telephony configuration (jtapi.ini)
• User prompts, grammars, and documents under these paths:
- c:\Program Files\wfavvid\Prompts\user
- c:\Program Files\wfavvid\Grammars\user
- c:\Program Files\wfavvid\Documents\user
thanks
