Nat over two WAN link
Apr 23rd, 2009
Hi all,
I have an issue trying to nat over two links. Currently I can only get it to work over one. I have static routes and I need to have it over both so that if one link is down we use the other link, link an automatic failover.
Below is my current config.
interface FastEthernet0
ip address xxx.xxx.xxx.173 255.255.255.248
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet1
ip address xxx.xxx.xxx.2 255.255.255.128
ip nat outside
speed 10
half-duplex
interface Vlan1
ip address 192.168.0.1 255.255.255.0
ip access-group Control in
ip nat inside
interface Async1
no ip address
encapsulation slip
ip route 0.0.0.0 0.0.0.0 xxx.xxx.xxx.169 151
ip route 0.0.0.0 0.0.0.0 xxx.xxx.xxx.1 152
no ip http server
no ip http secure-server
ip nat inside source static 192.168.0.2 interface FastEthernet0
ip access-list extended Control
permit ip 192.168.0.0 0.0.0.255 any
Overall Rating: 3 (1 ratings)
Sureshdank Thu, 04/23/2009 - 02:09
Are these Internet links or Interoffice leased lines.
If they are Internet links you can ask your service provider to route the public segment towards both the links at his end. So what happens when reverse packet comes to the ISP end it will find the route towards tow interfaces if any of them is down it will go to the secondary link. Auto load balancing will take place.
Please rate if helpfull.
regards,
Suresh Kumar
zenon_electronics Thu, 04/23/2009 - 06:52
you have to use the "extendable" command at the end of the NAT rule, for example:
ip nat inside source static 192.168.0.2 x.x.x.x extendable
ip nat inside source static 192.168.0.2 y.y.y.y extendable
where x.x.x.x and y.y.y.y are the ip addresses of your interfaces fa0 and fa1.
Make sure you use the IP address not "interdace fastEthernet" command.
Good luck and regards!
gbenga.shobowale Fri, 04/24/2009 - 00:27
Thanks but this did not give my desired result as nat now works on one interface but not the other.
I am hoping that the best of both worlds.. I will post another configuration I am trying soon.. just hoping it works
gbenga.shobowale Sat, 04/25/2009 - 07:39
ip sla 1
icmp-echo xxx.xxx.xxx.1
ip sla schedule 1 life forever start-time now
track 123 rtr 1 reachability
I tried this to monitor if the link is down.. but for some strange reason putting this on the routing table it says the link is down...
I had to remove it and having the
ip nat inside source static 192.168.0.2 xxx.xxx.xxx.169 extendable
ip nat inside source static 192.168.0.2 yyy.yyy.yyy.1 extendable
Solved the problem
thanks guys ... but really the problem is with the statement when i ping the gw (within the router) it timeout even though I am on the net. I can ping from a workstation.. just wondering ...
