best practices for high availiblilty on lan
Apr 23rd, 2009
Hi all
can anyone give me some best practices for setting up from access to dist layers on the lan, ie things I should set up for fast convergence, stp tuning, security etc ?
jedavis Fri, 04/24/2009 - 12:28
Try this for high-level overview:
And here are some best practices documents for the 4500 and 6500, though they is generic enough to apply to other platforms.
Look around CCO. There are a lot of good docs out there.
nidesai Tue, 04/28/2009 - 05:24
Go to and then select Campus, Two design guides
HA recovery Analysis
Routed ACcess Design
Finally VSS design guide will there shortly.
The previous reply has good info too - but it more operational. Above design guide helps you in terms of architecture and design view point.
