UCCX 7.01 - Remove Recording Button for Supervisor
Apr 23rd, 2009
  • Bronze, 100 points or more
Is there anyway to remove the recording button from the supervisor desktop? I can't seem to find it. I just can customize Agent Desktop,
Best regards,
met.
Overall Rating: 3 (1 ratings)
atalante Thu, 04/23/2009 - 02:35
I think it's not possible on CSD
regards
Jonathan Schulenberg Sat, 04/25/2009 - 17:43
  • Cisco Designated VIP,
    2017 IP Telephony
Like atalante said, this is not possible in CSD. If your desire is to disable this system-wide, my recommendation would be to disable SPAN to PC Port and Voice VLAN Access on all phones' configuration.
metalium2007 Sun, 04/26/2009 - 02:07
Thank you for the suggestion.
Met.
