ASA 5550
Apr 23rd, 2009
I've logged myself out of my ASA by forgettting to put in a pre-share key for my ACS server and i cant login as i had already set it to point to the ACS for command authorization and i put the "aaa authorization command ACS" and forgot to put the loca part so that i can make changes locally on the Device. Does anyone know how to bypass the "aaa authorization command ACS" even if it means reseting the configs? The problem is i can even login to the box at all. Does anyone know how to erase ASA configs without login on to the Device.(Like a reset button of some sort?
Trending Topics - Security & Network
