Ghost Image using Acronis Software on CCM Servers
Apr 23rd, 2009
Is there any way where we can install the Acronis Ghost Image Backup utility on CCM Servers, version 4.1(3) sr5b? If yes, is there a document for the same?
Overall Rating: 5 (1 ratings)
Jaime Valencia Thu, 04/23/2009 - 06:37
  • Cisco Employee,
  • Hall of Fame,
    2011
it has not been tested so it's not supported, BARS is the only supported app for backing CUCM.
you're free to try installing it hoping nothing will break, if it breaks something and TAC believes it's the issue they won't provide support until you uninstall it and cannot be sure if uninstalling it will be enough to revert changes, worst case scenario is rebuild the server from scratch
java
if this helps, please rate
Carl.Mayne-Wheeler Thu, 05/20/2010 - 07:44
Hello chaps,
do you know if GHOST is supported on any CCM/CUCM applications?
Thanks in advance.
Carl.Mayne-Wheeler Thu, 05/20/2010 - 08:13
One more question. Is the same answer for the likes of IPCC? I know unity uses DiRT.
