Access code with CCM in a centralized deployment
Apr 23rd, 2009
I've got a centralized deployment with CCM6 and two sites. I used two H.323 gateways and set the PSTN access code to 9. I defined my route pattern and put my gateways in a route list. My problem is that I've got most of the calls from site B routed the site A gateway. I've thought of two access codes but what if i've got 100 sites to deal with.
Please advice,
Jaime Valencia Fri, 04/24/2009 - 11:46
  • Cisco Employee,
  • Hall of Fame,
    2011
this is not a Video over IP question, please use the NetPro categories appropriately
use CSS and partitions to route the calls to the right GW depending on the source of the call
java
if this helps, please rate
