Can the CallManager See 2 LDAP Servers
Answered Question
Apr 23rd, 2009
We have CallManager 4.1.3 integrated with Windows Active Directory. We have 2 AD servers. The problems is that when the primary AD server goes down, the CallManager Directory Connection fails. How do I configure the CallManager to see the secondary AD server so it can use it as a backup?
Correct Answer by htluo about 7 years 9 months ago
You may try c:\dcdsrvr\DirectoryConfiguration.ini
Michael
Overall Rating: 5 (2 ratings)
zebranutz80 Thu, 04/23/2009 - 06:37
Thank you for responding Michael. Before I re-run the plugin, where can I check to see if the CallManager is already configured to see more than 1 AD server?
Correct Answer
htluo Thu, 04/23/2009 - 07:06
Michael
zebranutz80 Thu, 04/23/2009 - 09:27
That did it. Thank you Michael. I'm going to have to re-install the plug-in. I'm only configured for a single AD controller.
