4948 boot statements
Apr 23rd, 2009
I have 2 bootstatements in my config. is there a command to reorder those statements. I want the second statement to be the first. i want the switch to boot off the second statement.
Overall Rating: 5 (1 ratings)
Jon Marshall Thu, 04/23/2009 - 05:39
Easiest way is to
1) 4948(config)# no
2) 4948(config)#
ie. after step 1 you will only be left with the 2nd boot statement in your running config. Then just add back in the first boot statement which should then appear as the 2nd boot statement in the running config.
Note this is fine to do while the switch is up and running, it will have no effect until switch is rebooted.
Jon
