Pseudowire over TE MPLS
Apr 23rd, 2009
  • Gold, 750 points or more
Has anyone used Pseudowire over Traffic Enginnering MPLS?
What i would like to do is setup the MPLS TE using OSPF, built layer 3 tunnels between sites and then use Pseudowire to extend vlans over the TE MPLS tunnels and isolate the vlans using VRF-Lite.
Advice pls..
Francisco
Laurent Aubert Thu, 04/23/2009 - 09:53
  • Cisco Employee,
Hi Francisco,
You can map a PW to a MPLS-TE tunnel via the PW-class:
pseudowire-class TE
encapsulation mpls
preferred-path interface Tunnel0
interface Ethernet0/0
xconnect 1.1.1.1 10 pw-class TE
Laurent.
francisco_1 Wed, 05/13/2009 - 00:14
thanks Laurent.
I will give it a go...
Francisco
