Multicast RP problem
Answered Question
Apr 23rd, 2009
We are testing multicast in test environment between R1 and R2 connected by point-to-point serial link. configuration is as follows
R1.
ip multicast-routing
int fa0/0
ip pim sparse-dence
ip igmp join-group 224.1.1.1
int s1/0
ip pim sparse-dence
ip pim send-rp-announce s1/0 scope 5
ip pim send-rp-discovery s1/0 scope 5
R2.
int s1/0
ip pim sparse-dence
int fa0/0
ip pim sparse-dence
I can see the neighbor relationship
by command
show ip pim neighbor
show ip pim interface also shows that pim Sp.Den mode is enabled on all the interfaces. But when I give command
sh ip pim rp on R2 is doesnt show any RP.
On R1 it shows RP as directly connected.
Surprisingly if I ping to 224.1.1.1 from R2 is gives the response as reachable from next-hop address in .... miliseconds.
Show ip mroute on R2 shows only 224.0.1.39 and 224.0.1.40 listener addresses but no group of 224.1.1.1.
Do we really need a multicast stream generator running? Can ip ignp join-group command server the purpose.
Any experience please share.
Thanks in advance
Subodh
Correct Answer by Edison Ortiz about 8 years 10 hours ago
Subodh,
Not sure what you are missing but it works for me:
R1(f0/0)<--->(f0/0)R2
R1 has the loopback emulating the host with a join for group 224.1.1.1
interface Loopback0
ip address 1.1.1.1 255.255.255.255
ip pim sparse-dense-mode
no clns route-cache
end
It's also running PIM Auto-RP:
R1#sh run | i send
ip pim send-rp-announce FastEthernet0/0 scope 16
ip pim send-rp-discovery FastEthernet0/0 scope 16
R1#sh ip pim rp mapping
PIM Group-to-RP Mappings
This system is an RP (Auto-RP)
This system is an RP-mapping agent (FastEthernet0/0)
Group(s) 224.0.0.0/4
RP 192.168.12.1 (?), v2v1
Info source: 192.168.12.1 (?), elected via Auto-RP
Uptime: 00:03:52, expires: 00:02:04
R2 can see the Auto-RP announcement:
R2#sh ip pim rp mapping
Uptime: 00:04:34, expires: 00:02:22
You can also see it on the mroute as RP and mapping agent MCAST groups:
R2#sh ip mroute | i 192.168.12.1
(192.168.12.1, 224.0.1.39), 00:00:23/00:02:37, flags: PT
(192.168.12.1, 224.0.1.40), 00:03:24/00:02:33, flags: PLT
On R1, I can see the IGMP join for 224.1.1.1
R1#sh ip mroute | i 224.1.1.1
(*, 224.1.1.1), 00:04:53/00:02:28, RP 192.168.12.1, flags: SJCL
Pinging from R2:
R2#ping 224.1.1.1 repeat 10
Sending 10, 100-byte ICMP Echos to 224.1.1.1, timeout is 2 seconds:
Reply to request 0 from 192.168.12.1, 80 ms
Reply to request 1 from 192.168.12.1, 44 ms
Reply to request 2 from 192.168.12.1, 16 ms
Reply to request 3 from 192.168.12.1, 16 ms
Reply to request 4 from 192.168.12.1, 24 ms
Reply to request 5 from 192.168.12.1, 52 ms
Reply to request 6 from 192.168.12.1, 40 ms
Reply to request 7 from 192.168.12.1, 28 ms
Reply to request 8 from 192.168.12.1, 12 ms
Reply to request 9 from 192.168.12.1, 28 ms
R2#sh ip mroute 224.1.1.1
IP Multicast Routing Table
Flags: D - Dense, S - Sparse, B - Bidir Group, s - SSM Group, C - Connected,
L - Local, P - Pruned, R - RP-bit set, F - Register flag,
T - SPT-bit set, J - Join SPT, M - MSDP created entry,
X - Proxy Join Timer Running, A - Candidate for MSDP Advertisement,
U - URD, I - Received Source Specific Host Report, Z - Multicast Tunnel
Y - Joined MDT-data group, y - Sending to MDT-data group
Outgoing interface flags: H - Hardware switched, A - Assert winner
Timers: Uptime/Expires
Interface state: Interface, Next-Hop or VCD, State/Mode
(*, 224.1.1.1), 00:00:38/stopped, RP 192.168.12.1, flags: SPF
Incoming interface: FastEthernet0/0, RPF nbr 192.168.12.1
Outgoing interface list: Null
(192.168.12.2, 224.1.1.1), 00:00:38/00:02:39, flags: PFT
Incoming interface: FastEthernet0/0, RPF nbr 0.0.0.0
HTH,
__
Edison.
Overall Rating: 5 (1 ratings)
Correct Answer
Edison Ortiz Thu, 04/23/2009 - 07:17
  • Hall of Fame,
    Founding Member
Subodh,
interface Loopback0
no clns route-cache
end
R1#sh run | i send
Pinging from R2:
HTH,
__
Edison.
