show l2tp memory detail
Apr 23rd, 2009
Attached is the output from the command
show l2tp memory detail.
I need some help to understand the memory In-use/Allocated. Are these values taken from the total memory from the router?
There are some itens from "Allocator-Name" using 99%. Can this generate some problems in equipment's performace?
Thank you,
Wanderley.
