How to "Inserting Remote Destination" in Bulk
Answered Question
Apr 23rd, 2009
Hi there,
How I can Inserting Remote Destination in Bulk using BAT? In BAT tool I only got the option to insert Remote Destination Profile and not Remote Destination. I read about this topic in Help section and the following has ben mentioned:
You must have a data file in comma separated value (CSV) format that contains the unique details for the remote destination.
My question is: How I can create data and with which fields?
Thanks.
YSana
Correct Answer by Sascha Monteiro about 7 years 9 months ago
well, I looked on a cucm6.1(3) install, and there is an option in BAT to add Remote Destinations... it has an example file as well
Overall Rating: 5 (1 ratings)
Correct Answer
Sascha Monteiro Thu, 04/23/2009 - 11:58
