mail flow - download where?
Apr 23rd, 2009
Hi gurus, i know that this is already eol..correct me if im wrong..but i have my c10 with a problem on mailflow. im going to reinstall it using version 1.4.
any idea where i can download it? or any tips maybe.
thank you.
kira
steven_geerts Sat, 04/25/2009 - 22:24
HI Kira,
To me it's not clear what your question is. Please make it some more clear.
If I understand you right you have an old C10 with a problem in it's mail flow.
Or.... are you trying to re-use a C10 for Mail Flow Central (MFC)? And are you seeking the MFC software? If this last is the case, to things:
1) You loose your warranty and support on the C10 if you install an other OS on it. (Besides the fact that Ironport appliances do not have a video card installed, which is needed for most OS installations).
2) You can get your MFC software via your sales contact.
If I totally misunderstood you, please clarify your question.
Best Regards,
Steven
