Cisco 1841 Startup-config question
Answered Question
I understand that the startup-configs reside on the nvram on the 1841 but is it possible to house these configs on the flash drive.
Here's my problem, have 60 - 1841's in remote offices. We are going with a new ISP. Instead of sending another router or using a modem to connect in to the router I thought I could have the configuration & IOS on a flash, ship the flash & have a user replace the flash with the new configuration.
Correct Answer by Joe Clarke about 7 years 9 months ago
Why not simply copy the new startup config into the NVRAM on the existing routers? That is, right before the ISP switchover, upload a new config file into startup-config, then reload the router. When the router comes back up, you'll be on the new ISP.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Thu, 04/23/2009 - 10:10
