ASA EIGRP Static Route
smalkeric Wed, 04/29/2009 - 12:41
  • Silver, 250 points or more
You can try redistributing the static route into EIGRP in this scenario. You can optionally configure route redistribution. The Cisco ASA can redistribute routes discovered by RIP and OSPF into the EIGRP routing process. You can also redistribute static and connected routes into the EIGRP routing process. You do not need to redistribute static or connected routes if they fall within the range of a network configured on the Setup > Networks tab. Define route redistribution on the Redistribution pane.
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a008086ebd2.shtml
