What is a WS-X45-SUP6L-E?
Apr 23rd, 2009
I am trying to configure a 4507 and was using a SupV. I tried putting a 24 port fiber card and it complained and said you could replace with a WS-X45-SUP6L-E which is about 5k cheaper. I cannot find any info on this supervisor at all. Does is have the same features and backplane as the WS-X45-SUP6-E whats the difference?
WS-X45-SUP6L-E
Catalyst 4500 E-Series Sup 6-E Lite, 2x10GE(X2) w/ Twin Gig
(4500R-E SLOT 3 OPT:4507R-E SLOT 3 OPT:WS-X45-SUP6L-E)
I
Overall Rating: 5 (1 ratings)
Sushil Kumar Katre Thu, 04/23/2009 - 19:49
  • Gold, 750 points or more
Hi Michael,
Cisco has released this new sup on 4500s & its called SUP6-e Lite as evident fromt the description you have given.
It comes with dual 10GE uplinks with support for Twingig converter to get 4 1GE ports.
Switching Capacity - 280Gbps on 4507R-E chassis
260Gbps on 4506-E chassis
116Gbps on 4503-E chassis
Throughput - 225Mpps for IPv4 & 110Mpps for IPv6
512 MB DRAM upgradable to 1GB
Support ONLY Static Routing, RIP, RIPv2 and EIGRP Stub with no option to upgrade the IOS and get advanced routing protocol supported (OSPF, BGP, EIGRP).
-> Sushil
