BGP distribute list problem
DialerString_2
Level 3
Level 3
I'm trying to prevent a single host address from being injected into my providers MPLS network and even with the distribute-list it stills show up in the AS. Thanks..
router bgp 200
no synchronization
bgp log-neighbor-changes
network 10.2.20.0 mask 255.255.255.0
redistribute connected
neighbor 1.1.1.1 remote-as 65000
neighbor 1.1.1.1 route-map SETMED out
distribute-list 10 out
-even tried neighbor 1.1.1.1 distribute-list "" out
access-list 10 deny host 12.12.12.12
access-list 10 permit any
clear ip bpg *
clear ip route
int loopback 1
ip address 1.1.1.1 255.255.255.255
Jon Marshall
Eric
Just tested this with dynamips and it works fine for me, so as long as you have an exact matching route ie. 12.12.12.12 then it should work fine.
Jon
9 Replies 9
Richard Burts
Eric
Where is 12.12.12.12/32 coming from? Is it a connected interface?
Also I am puzzled at parts of your config. You configure your BGP with a neighbor of 1.1.1.1, but it appears that 1.1.1.1 is a loopback interface on your router. Can you clarify what is going on?
Rick
Rick
Sorry guys about the incomplete config and 12.12.12.12 is Dialer interface that's setup for DSL.
router bgp 200
no synchronization
clear ip bpg *
clear ip route
int loopback 1
ip address 10.10.10.10 255.255.255.255
int di0
ip address 12.12.12.12 255.255.255.255
here is the complete config. and i"ve tried clear ip bgp *
Eric,
You should definitely use "neighbor 1.1.1.1 distribute-list 10 out".
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Hi Harold, this works.
But I have the same problem, it seems like the distribute doesn't work if I don't put it on specific neighbour.  Do you have any idea about that?
Thanks.
Okay try this
access-list 10 deny 12.12.12.12
route-map FILTER permit 10
match ip address 2
router bgp 200
redistribute connected route-map FILTER
and remove
distribute-list 10 out from bgp config. Then as Harold says "clear ip bgp 1.1.1.1 soft out"
Jon
Harold Ritter
Eric,
Did you try "neighbor 1.1.1.1 distribute-list 10 out", followed by a "clear ip bgp 1.1.1.1 soft out". That should definitely work for you.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Jon Marshall
Eric
Jon
Hmmm. Well I'm specifying the host address int the acl and distribute list. I know that with BGP the routes have to be exact match in order to be in the bgp routing table. Does this apply for the distribute list also?
thx
