WS-C3750E-48PD errors
Apr 23rd, 2009
I am trying to figure out why I am getting these error messages on my 3750E switch:
Apr 23 18:34:39: %SFF8472-5-THRESHOLD_VIOLATION: Te1/0/1: Tx power low alarm; Operating value: -32.2 dBm, Threshold value: -12.2 dBm.
Apr 23 18:44:39: %SFF8472-5-THRESHOLD_VIOLATION: Te1/0/1: Tx power low alarm; Operating value: -32.2 dBm, Threshold value: -12.2 dBm.
Apr 23 18:54:40: %SFF8472-5-THRESHOLD_VIOLATION: Te1/0/1: Tx power low alarm; Operating value: -32.2 dBm, Threshold value: -12.2 dBm.
Apr 23 18:58:46: %SYS-5-CONFIG_I: Configured from console by gstewart on vty0 (10.24.133.149)
Apr 23 19:04:40: %SFF8472-5-THRESHOLD_VIOLATION: Te1/0/1: Tx power low alarm; Operating value: -32.2 dBm, Threshold value: -12.2 dBm.
Any suggestions?
Leo Laohoo Thu, 04/23/2009 - 14:29
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Can you please post the result of the following commands:
sh post
sh environ alarm
sh run interface Te1/0/1
everett5252 Thu, 04/23/2009 - 14:43
everything passed in the show post.
no issues with the env
IT-ROOM-264-IDF# sh run interface Te1/0/1
Building configuration...
Current configuration : 128 bytes
interface TenGigabitEthernet1/0/1
switchport mode trunk
channel-group 14 mode on
end
IT-ROOM-264-IDF#show interface Te1/0/1
TenGigabitEthernet1/0/1 is down, line protocol is down (err-disabled)
Hardware is Ten Gigabit Ethernet, address is 0024.974e.8bb5 (bia 0024.974e.8bb5)
MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec,
reliability 253/255, txload 1/255, rxload 1/255
Keepalive not set
Full-duplex, 10Gb/s, link type is auto, media type is 10GBase-LR
input flow-control is off, output flow-control is unsupported
Last input never, output 04:17:08, output hang never
Queueing strategy: fifo
Output queue: 0/0 (size/max)
0 packets input, 144 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
5 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 0 multicast, 0 pause input
19 packets output, 1216 bytes, 0 underruns
0 output errors, 0 collisions, 5 interface resets
Leo Laohoo Thu, 04/23/2009 - 17:09
  • Hall of Fame,
    2017 LAN, Wireless
How about "sh interface Ten1/0/1 trans detail"?
everett5252 Fri, 04/24/2009 - 04:19
IT-ROOM-264-IDF#sh interface Ten1/0/1 trans detail
ITU Channel not available (Wavelength not available),
Transceiver is internally calibrated.
mA: milliamperes, dBm: decibels (milliwatts), NA or N/A: not applicable.
++ : high alarm, + : high warning, - : low warning, -- : low alarm.
A2D readouts (if they differ), are reported in parentheses.
The threshold values are calibrated.
High Alarm High Warn Low Warn Low Alarm
Temperature Threshold Threshold Threshold Threshold
Port (Celsius) (Celsius) (Celsius) (Celsius) (Celsius)
Te1/0/1 32.7 74.0 70.0 0.0 -4.0
Voltage Threshold Threshold Threshold Threshold
Port (Volts) (Volts) (Volts) (Volts) (Volts)
Te1/0/1 0.00 3.63 3.46 3.13 2.96
Optical High Alarm High Warn Low Warn Low Alarm
Transmit Power Threshold Threshold Threshold Threshold
Port (dBm) (dBm) (dBm) (dBm) (dBm)
Te1/0/1 -2.0 4.5 0.5 -8.2 -12.2
Receive Power Threshold Threshold Threshold Threshold
Te1/0/1 -4.8 4.5 0.5 -14.1 -18.4
IT-ROOM-264-IDF#
Leo Laohoo Sun, 04/26/2009 - 15:56
  • Hall of Fame,
    2017 LAN, Wireless
Don't know with the other's opinion but your module (Ten 1/0/1) is has triggered an alarm after exceeding the lower treshold limit of -12.2dBm.
My recommendation is to get the module RMA-ed.
