Port 4697?
Answered Question
Apr 23rd, 2009
Is opening port 4697 ok/secure? Using ASA 5520. It is the only port that will allow me to connect, remotely, to my SQL server via SQL Server Management Studio. I tried 1433 & 1434, but to know avail.
TIA
Correct Answer by John Blakley about 7 years 11 months ago
You can open 4697 if that's the only one that will work. Keep in mind that any port you open allows for an attacker a door into your network. Your SQL server needs to have the latest security patches installed, locked down, etc.
HTH,
John
Overall Rating: 5 (1 ratings)
Correct Answer
John Blakley Thu, 04/23/2009 - 11:51
  • Purple, 4500 points or more
HTH,
John
