Change ASA telnet password
Apr 23rd, 2009
I normally logon to our ASA using my SSH2 username and password.
Thing is if I telnet to our ASA it asks for a password which nobody knows, how can I change this as I have access via SSH to do this?
John Blakley Thu, 04/23/2009 - 12:07
  • Purple, 4500 points or more
If you want to login with your ssh credentials, then you can enable telnet through aaa.
aaa authentication telnet console LOCAL
If you aren't using aaa, then the "passwd" command changes the telnet login password.
*LOCAL is all uppercase.
HTH,
John
