Multicast "Register", "Join" ...
Apr 23rd, 2009
I some doubts about Multicasting :
1.In case of RP defined in shared tree. How terms are used for Multicast sources and multicast users related to --
Who joins/register at RP. what is the difference between Join and register from Multicast-source and the end user point.
2. When a multicast stream packet is sent to RP by source server what is the IP address source and dest of such packet?
3. When a packet is forwared down to user by RP what is the IP address of such packet so that it gets routed to the last router where users are connected. ( in my opinion dest IP = Multicast-group_IP_224.1.1 so that it can be delivered to the actual end user systems ).
3. routers in between the RP and the end uses do they need to be member of the group or they can just accept the multicast packets for any group and forward it to other interface or more that one interfaces as a next hop towards user?
Any explanation please share.
Thanks in advance
Subodh Bapat
Edison Ortiz Thu, 04/23/2009 - 13:50
All questions covered in CCO, pasting for clarity:
PIM Sparse Mode
PIM sparse mode (PIM-SM) uses a pull model to deliver multicast traffic. Only network segments with active receivers that have explicitly requested the data will receive the traffic.
Unlike dense mode interfaces, sparse mode interfaces are added to the multicast routing table only when periodic Join messages are received from downstream routers, or when a directly connected member is on the interface. When forwarding from a LAN, sparse mode operation occurs if an RP is known for the group. If so, the packets are encapsulated and sent toward the RP. When no RP is known, the packet is flooded in a dense mode fashion. If the multicast traffic from a specific source is sufficient, the first hop router of the receiver may send Join messages toward the source to build a source-based distribution tree.
PIM-SM distributes information about active sources by forwarding data packets on the shared tree. Because PIM-SM uses shared trees (at least, initially), it requires the use of a rendezvous point (RP). The RP must be administratively configured in the network. See the "Rendezvous Points" section for more information.
In sparse mode, a router assumes that other routers do not want to forward multicast packets for a group, unless there is an explicit request for the traffic. When hosts join a multicast group, the directly connected routers send PIM Join messages toward the RP. The RP keeps track of multicast groups. Hosts that send multicast packets are registered with the RP by the first hop router of that host. The RP then sends Join messages toward the source. At this point, packets are forwarded on a shared distribution tree. If the multicast traffic from a specific source is sufficient, the first hop router of the host may send Join messages toward the source to build a source-based distribution tree.
Sources register with the RP and then data is forwarded down the shared tree to the receivers. The edge routers learn about a particular source when they receive data packets on the shared tree from that source through the RP. The edge router then sends PIM (S,G) Join messages toward that source. Each router along the reverse path compares the unicast routing metric of the RP address to the metric of the source address. If the metric for the source address is better, it will forward a PIM (S,G) Join message toward the source. If the metric for the RP is the same or better, then the PIM (S,G) Join message will be sent in the same direction as the RP. In this case, the shared tree and the source tree would be considered congruent.
If the shared tree is not an optimal path between the source and the receiver, the routers dynamically create a source tree and stop traffic from flowing down the shared tree. This behavior is the default behavior in Cisco IOS software. Network administrators can force traffic to stay on the shared tree by using the Cisco IOS ip pim spt-threshold infinity command.
http://www.cisco.com/en/US/docs/ios/ipmulti/configuration/guide/imc_tech_oview_ps6350_TSD_Products_Configuration_Guide_Chapter.html
HTH,
__
Edison.
