How do I convert AIR-LAP512G-A-K9 to autonomous?
Answered Question
Apr 23rd, 2009
Any help you can offer will be greatly appreciated!
Per
Correct Answer by Scott Fella about 8 years 1 month ago
Don't know too much about these, but if they are like the other LAP's then take a look at this documentation. Look for this:
Using a TFTP Server to Return to a Previous Release
http://www.cisco.com/en/US/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html#wp161272
Overall Rating: 5 (1 ratings)
Correct Answer
Scott Fella Thu, 04/23/2009 - 18:26
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Sushil Kumar Katre Thu, 04/23/2009 - 20:59
  • Gold, 750 points or more
Even I have not dealt with this AP earlier. but looks like the Lightweight AP can not be converted to Autonomous afer doing a search on cisco.com.
Although there is no document which explicitely states this but this is what release notes states -
Converting an Autonomous AP521 Using the CCA -
When an autonomous AP521 access point is converted to controller-mode operation using the CCA, the access point properties screen continues to indicate that the access point is an AIR-AP521G-A-K9 after the conversion. This is in agreement with the product label on the access point. However, the CCA displays a small triangle icon next to the converted access point to indicate that the access point is now operating as a controller-mode access point.
Note The CCA conversion process is one-way. Once the conversion takes place, you cannot restore the access point to autonmous operation.
http://www.cisco.com/en/US/docs/wireless/access_point/521/release/notes/iosap521rn1234jx1.html#wp243837
Another link which talks about the conversion of Autonomous to Lightweight with the same restriction. It does not talks about LWAP to Auto conversion -
http://www.cisco.com/en/US/docs/wireless/controller/526/1.5/configuration/guide/A2_aap.html#wp1013636
-> Sushil
Leo Laohoo Thu, 04/23/2009 - 21:15
  • Hall of Fame,
    2017 LAN, Wireless
I'm no expert with this model. Can the AP join the WLC? If so, I would like to ask if you can invoke the following CLI command on the WLC:
config ap tftp-downgrade
Hope this helps.
per_2 Fri, 04/24/2009 - 09:07
Thanks for your response.
I was able to get the conversion done as follows:
tftp with correct image name modified to "c521-k9w7-tar.default". tftp server ip 10.0.0.2/27
repower the 521 holding the mode button until LED's go red (30 seconds). AP will broadcast for tftp service and load the image if it's name as above - make sure you dont have firewill services up!
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
