Routing or Accesslist help needed . . . !!!
Apr 23rd, 2009
Hii Everybody,
I have recently upgraded my Internet connection from 2*2 mbps multilink to 10 Mbps Internet line where RJ45 ethernet input given in Giga ethernet 1 . I have connected my Giga ethernet 2 to my firewall .
I have simply assigned WAN ip on Ethernet 1 and my first avalable ip from public ip pool on ethernet 2 . and the next available ip on firewall WAN port .
Assigned a default route towards WAN ip of my service provider .
Do I need to make any other changes here , Do i need to add any access-list here , as i am new to WAN do let me know with example .
Also let me know do i need to get in touch my service provider in adding any additional configuration .
!INTERFACE AND SUB-INTERFACE
interface GigabitEthernet 1
description " Internet Link 10Mbps "
ip address 1.1.1.2 255.255.255.252
no shutdown
interface GigabitEthernet 2
description " *** Connected to Firewall *** "
speed 100
duplex full
ip address x.x.x.x 255.255.255.248
no shutdown
interface GigabitEthernet 3
description " *** Standby & Testing *** "
no shutdown
!IP
ip route 0.0.0.0 0.0.0.0 1.1.1.1
Regds,
Max
Edison Ortiz Fri, 04/24/2009 - 06:49
  • Hall of Fame,
    Founding Member
Based on the information provided, I believe you've covered all basis.
I don't think you need to get in touch with the SP unless you are unable to ping the internet while sourcing from interface GigabitEthernet 2.
You should also try pinging the interface from the WAN facing interface in the FW device.
Best of luck
__
Edison.
