Problem with 8 port T1 in 7206
Apr 23rd, 2009
We have an 8 port T1 card on the shelf that we inserted into a 7206. The router displays the following:
%C7200-4-PCIVALID: PCI activation failed, bay 2, 0x11133102
%PA-2-UNDEFPABRIDGE: Unsupported Port Adaptor Bridge 0x0 in bay 2
%PA-2-PABRIDGE: Failed to config bridge for PA 2
Do you know if this is a hardware problem with the router or card?
paolo bevilacqua Fri, 04/24/2009 - 05:35
  • Hall of Fame,
    Founding Member
You show check show diag, and show c7200 to see what exact hardware do you have, and what compatibility issue there may be.
