Simple dual WAN with load balancing and failover on the 1811
Apr 23rd, 2009
I'm trying to follow the famous example here:
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a00808d2b72.shtml
The only difference with my configuration is both of my ISP connections have static IPs (so it should be eaiser to configure you would think.)
Anyway I can only get one or the other connections to work, never both at the same time. Attached is my current config. This config the ETH0 is the one that most traffic goes over.
Current configuration : 7238 bytes
version 12.4
hostname yourname
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
ip cef
ip domain name yourdomain.com
ip name-server 64.105.199.74
ip name-server 64.105.159.250
no ipv6 cef
username root privilege 15 secret 5 $1$ifix$nrWAT5zZIA13Av41XLjMm/
archive
log config
hidekeys
track timer interface 5
interface FastEthernet0
description COVAD$ETH-LAN$
ip address cc.cc.cc.26 255.255.255.248
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet1
description VERIZON$ETH-LAN$
ip address vv.vv.vv.7 255.255.255.0
ip nat outside
shutdown
duplex auto
speed auto
interface FastEthernet2
description 240 NAT
switchport access vlan 239
interface FastEthernet3
description 240 NAT
interface FastEthernet4
description 10 DIAG
interface FastEthernet5
description 10 DIAG
interface FastEthernet6
description 10 DIAG
interface FastEthernet7
description 10 DIAG
interface FastEthernet8
description 10 DIAG
interface FastEthernet9
description 10 DIAG
interface Vlan1
description DIAG VLAN$ETH-SW-LAUNCH$$INTF-INFO-FE 2$
ip address 10.10.10.1 255.255.255.248
ip tcp adjust-mss 1452
interface Vlan239
description THE NAT
ip address 192.168.140.2 255.255.255.0
ip nat inside
interface Async1
no ip address
encapsulation slip
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 vv.vv.vv.1 permanent
ip route 0.0.0.0 0.0.0.0 cc.cc.cc.25 permanent
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source route-map fixed-covad interface FastEthernet0 overload
ip nat inside source route-map fixed-verizon interface FastEthernet1 overload
ip sla 1
icmp-echo vv.vv.vv.1 source-interface FastEthernet1
timeout 1000
threshold 40
frequency 3
ip sla schedule 1 life forever start-time now
ip sla 2
icmp-echo cc.cc.cc.25 source-interface FastEthernet0
timeout 1000
threshold 40
frequency 3
ip sla schedule 2 life forever start-time now
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 192.168.140.0 0.0.0.255
access-list 23 permit 10.10.10.0 0.0.0.7
access-list 23 permit 192.168.140.0 0.0.0.255
access-list 110 permit ip 192.168.140.0 0.0.0.255 any
no cdp run
route-map fixed-covad permit 10
match ip address 110
match interface FastEthernet0
set ip next-hop cc.cc.cc.25
route-map fixed-verzion permit 10
match interface FastEthernet1
set ip next-hop vv.vv.vv.1
control-plane
line con 0
line 1
modem InOut
stopbits 1
speed 115200
flowcontrol hardware
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
transport input telnet ssh
line vty 5 15
access-class 23 in
privilege level 15
webvpn cef
end
Overall Rating: 3 (1 ratings)
Laurent Aubert Fri, 04/24/2009 - 06:14
I suppose you noticed Fast1 is in shutdown state.
Load-balancing is per flow so you need different combination of source and destination addresses.
Also I don't think you need the set ip next-hop in the route-map as the routing decision is already made.
Other than that I don't know why it shouldn't work.
Laurent.
cowmixtoo Fri, 04/24/2009 - 13:46
The test I am doing is where I have a constant ping going out to a host on the general Internet. I take turns turning one connection off and the other on (and then vice versa) and the ping only persists when a certain connection is active.
I've corrected the issues you identified and the problem still persists.
Laurent Aubert Mon, 04/27/2009 - 07:38
It's due to the permanent keyword in your static route. Remove it from both routes so the route associated to a down interface will also be removed from the routing table.
Laurent.
