VPN lab help between Pix and router
Apr 24th, 2009
I'm trying to create a VPN in my lab setup.
I have a Cisco Pix 515 and a Cisco 2621 router.
I don't have a crossover cable yet, so the outside of the firewall is plugged into a hub and the outside interface FE 0/0 on the router is plugged into the hub too.
The router can ping the outside IP of the Pix.
I must be missing something as I have added the VPN commands to the router and Pix and enabled debugging on the crypto ISAKMP but I see nothing.
The Pix LAN is
The Router LAN is
Pix Outside is
Router Outside is
Using AES-256 SHA, DH Group 5
Hopefully you can see whatthe issue is, I am almost going to eraze both configs and start again.
