EzVPN and Radius
Answered Question
Apr 24th, 2009
I have configured a Router to use Radius ( MS IAS ) for console and telnet logins . I also want the vpn users connecting to that router to be authenticated with the Radius server . I have configured the router however I am not able to get the vpn client connected to the Router ( ezvpn server )
The configuration is below of the Router:
Router#sh run
Building configuration...
Current configuration : 1585 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
aaa new-model
aaa group server radius AUTH
server 172.16.1.243 auth-port 1645 acct-port 1646
aaa authentication login AUTH group radius
aaa authorization exec default group radius
aaa authorization network AUTH group radius
aaa session-id common
memory-size iomem 5
ip cef
ip address-pool dhcp-pool
crypto isakmp policy 10
encr 3des
authentication pre-share
group 2
crypto isakmp client configuration group AAA
key vpnuser
dns 10.0.1.13 10.0.1.14
domain cisco.com
pool Remote-Pool
save-password
crypto ipsec transform-set VPNTRANSFORM esp-3des esp-sha-hmac
crypto dynamic-map Dynamic-Map 10
set transform-set VPNTRANSFORM
reverse-route
crypto map ClientMap client authentication list AUTH
crypto map ClientMap isakmp authorization list AUTH
crypto map ClientMap client configuration address respond
crypto map ClientMap 65535 ipsec-isakmp dynamic Dynamic-Map
interface FastEthernet0/0
ip address 172.16.1.241 255.255.255.0
duplex auto
speed auto
ip local pool Remote-Pool 10.0.1.100 10.0.1.150
ip http server
no ip http secure-server
ip radius source-interface FastEthernet0/0
radius-server host 172.16.1.243 auth-port 1645 acct-port 1646 key xxxxxx
control-plane
line con 0
exec-timeout 0 0
line aux 0
line vty 0 4
login authentication AUTH
end
When I dial using the Cisco Easy VPN Client i get a debug error of :
%CRYPTO-6-IKMP_NOT_ENCRYPTED: IKE packet from 172.16.1.242 was not encrypted and it should've been.
I have searched on google and thought that the problem would have been with the Group ID and Password
In my case the Group ID is AAA and password is vpnuser.
But still I cant VPN into the router.
I think it is a problem associated with AAA because in books I have read and seen configuration of EzVPN using the local database and here I am authenticating them with IAS . But it should work fine as I am able to telnet into the router using my Active Directory/IAS account i.e. [email protected]
Please help
Correct Answer by Ivan Martinon about 7 years 9 months ago
Change this line:
to be
aaa authorization network AUTH local
Overall Rating: 4.5 (2 ratings)
Correct Answer
Ivan Martinon Fri, 04/24/2009 - 09:34
Change this line:
to be
Alcides Miguel Tue, 12/14/2010 - 09:08
I was working on this with no success and you help me a lot... thanks for your help
