Interference Energy ??
Apr 24th, 2009
My question is what exactly is Interference Energy ? What is the difference between Interference Energy the first measurement and Interference the last measurement in the mesaage below. Thanks for any explanations
AP 'AP.REJB.457', interface '802.11b/g' on Controller '192.168.10.10'. Channel changed to '11' from '1' due to 'Interference'. Interference Energy before update is '-53' and after update is '-81'. Noise before update is '-82' and after update is '-82'. Interference before update is '-53' and after update is '-118'.
weterry Fri, 04/24/2009 - 21:01
  • Silver, 250 points or more
I'll take a stab at this:
What version of code are you on?
I normally see the message as just "energy" not "interference energy". And the energy I've taken to understand that it means basically the overall RF energy in the AIR all things considered (noise, interference, valid 802.11 traffic, etc... but I could be mistaken).
Anyhow, DCA kicked in because your interference was so high, and it obviously did its job if you went from a -53 to -118.
Bottom line, I'm pretty sure this message in newer code (5.2) just says "energy", maybe because it is misleading that there is another "interference" listed.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
