2 SUP Card in 6500 Series Switch - One was faulty and need to replace ....
Apr 24th, 2009
Dear Experts,
We have 6506 Core switch with 2 SUP card. in Last week one was become faulty and now I have replaced it with new one.
During the time other SUP is in designated mode and working ok. NW is UP. System is configured with HSRP.
Now the steps I had taken for replaceing it are :
1. Plug the new SUP card in slot.
2. Console it and configured High Avialability + Config Sync.
3. In a second the whole cofiguration was coppied in new Card.
But the the problem i found that the HSRP priority was not seen in new Card ..Rest of the config is there in new Card ?
Why this happen and how to resolve it ...
pls suggest the steps....or docs...
Dipesh P.
Giuseppe Larosa Fri, 04/24/2009 - 04:28
  • Hall of Fame,
    Founding Member
Hello Dipesh,
if you use SSO for redundancy the following applies to you:
The Hot Standby Routing Protocol (HSRP) is not SSO-aware, meaning state information is not maintained between the active and standby supervisor engine during normal operation. HSRP and SSO can coexist but both features work independently. Traffic that relies on HSRP may switch to the HSRP standby in the event of a supervisor switchover.
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/nsfsso.html#wp1105901
if HSRP is not SSO aware from the point of view of HSRP the two supervisors are competitors for the role of active router.
From this should come the fact that standby priority command is not copied in new card
Hope to help
Giuseppe
Dipesh Patel Fri, 04/24/2009 - 19:56
Dear Sir,
Yes HSRP is not aware of SSO.
I am showing the part of config for both the SUP.
SUP - 1 which is active with Priotiry 115 as shown : Designated
Config:
mls rp ip
redundancy
high-availability
config-sync
interface Loopback0
ip address 192.168.201.251 255.255.255.0 alt ip address 192.168.201.252 255.255.255.0
interface Vlan100
description ***** System VLAN *****
ip address 10.15.101.32 255.255.255.0 alt ip address 10.15.101.34 255.255.255.0
no ip redirects
standby 2 priority 120 preempt alt standby 2 priority 115
standby 2 ip 10.15.101.35 alt standby 2 ip 10.15.101.35
hold-queue 125 in
line con 0
exec-timeout 0 0
line vty 0 4
exec-timeout 0 0
password _______________
login local
transport input lat pad mop telnet rlogin udptn nasi
ntp clock-period 17180048
ntp server 10.15.102.52
end
SUP - 2 Which is not active and in nondesignated MOde
Config:
mls rp ip
redundancy
high-availability
config-sync
interface Loopback0
interface Vlan100
no ip redirects
hold-queue 125 in
line con 0
exec-timeout 0 0
line vty 0 4
exec-timeout 0 0
login local
end
Now I need to Add HSRP priority in SUP2 .....
Can you guide me how should I proceed for the same with no down time or as much as minimum downtime?
Pls reply soon....
Dipesh P.
