04-24-2009 04:26 AM - edited 03-18-2019 10:55 PM
Running UCM 6.1. I can add a route pattern without any wildcards and outbound calls are successful to the specific pattern. I have installed the Australian dial plan (AUNP) using 0.@ as a route pattern. Dialing the same number which works as a specific route pattern entry results in a busy tone. I am stripping everything preAt (0) and ISDN debugs seem ok.
Any clues to the solution here would be appreciated.
Thanks.
Matt Naismith.
04-27-2009 08:47 PM
ISDN Q931 Debug of a failed call.
Apr 28 04:35:06.718: ISDN Se0/0/0:15 Q931: SETUP pd = 8 callref = 0x0004
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability= Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839F
Exclusive, Channel 31
Calling Party Number i = 0x0081, '555'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '0418796732'
Apr 28 04:35:06.730: ISDN Se0/0/0:15 Q921: User RX <- RR sapi=0 tei=0 nr=7
Apr 28 04:35:06.770: ISDN Se0/0/0:15 Q921: User RX <- INFO sapi=0 tei=0, ns=9 nr=7
Apr 28 04:35:06.770: ISDN Se0/0/0:15 Q931: CALL_PROC pd = 8 callref = 0x8004
Apr 28 04:35:06.774: ISDN Se0/0/0:15 Q921: User TX -> RR sapi=0 tei=0 nr=10
Apr 28 04:35:09.890: ISDN Se0/0/0:15 Q921: User TX -> INFO sapi=0 tei=0, ns=7 nr=10
Apr 28 04:35:09.890: ISDN Se0/0/0:15 Q931: DISCONNECT pd = 8 callref = 0x0004
Cause i = 0x8490 - Normal call clearing
I have upgraded to 6.1.3B and problem still exists. I'm also runnning MGCP on a 2811. Can help to feel i'm missing something obvious...
04-28-2009 05:33 AM
Can you post the full debug here. The debug you have posted is missing some things. eg, I cant see the beginning of the disconnect. This will tell us which side is disconnecting the call..
04-28-2009 02:24 PM
Hi, thanks.
Here is a call with ISDN Q931 debug.. Its the only call hitting the gateway so its output should be complete.
Thanks.
Matt.
Apr 28 22:12:40.722: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x000D
Sending Complete
Standard = CCITT
Transfer Capability = Speech
Called Party Number i = 0xA1, '0418796723'
Plan:ISDN, Type:National
Apr 28 22:12:41.766: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x800D
Apr 28 22:12:41.770: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x800D
Cause i = 0x849F - Normal, unspecified
Progress Ind i = 0x8288 - In-band info or appropriate now available
Apr 28 22:13:02.998: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x000D
Apr 28 22:13:03.026: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x800D
Here a call to the same number but with a specific route pattern which works fine.
Apr 28 22:18:51.939: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x0011
Sending Complete
Standard = CCITT
Called Party Number i = 0x80, '0418796723'
Apr 28 22:18:51.983: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x8011
Apr 28 22:18:57.495: ISDN Se0/0/0:15 Q931: RX <- PROGRESS pd = 8 callref = 0x8011
Progress Ind i = 0x8488 - In-band info or appropriate now available
Apr 28 22:18:57.543: ISDN Se0/0/0:15 Q931: RX <- ALERTING pd = 8 callref = 0x8011
Apr 28 22:19:01.099: ISDN Se0/0/0:15 Q931: RX <- CONNECT pd = 8 callref = 0x8011
Date/Time i = 0x09041D0813
Apr 28 22:19:01.103: ISDN Se0/0/0:15 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x0011
Apr 28 22:19:05.463: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x8011
Cause i = 0x809F - Normal, unspecified
Apr 28 22:19:05.503: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x0011
Apr 28 22:19:05.535: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x8011
04-29-2009 03:41 AM
Its looking like this is a bug. Tac yet to verify.
I replaced the 0.@ on the route pattern with 0.! and it works fine.
Matt.
10-05-2010 07:47 AM
Hi All,
Know this is an old bug, but I am having the same issue whereby I;
1. install the aunp
2. create a route pattern 0.@
3. set the number plan to aunp
4. Dont strip (as I am lazy and do it on the voice gateway)
For some reason on this installation, it simply dont work. I can go and replace it with 0.! and it works fine, but then I lose all my other things like filtering premium and international.
Is anyone else coming across this on cucm 6.1 using IDP AUNP 1.1(9)
I only get this in my lab on vm running on windows, not my lab running on my mac....
john
Sydney, Australia
